THE REBIRTH OF NUMBER 74
Kevin frazier
Widowmaker!
Nashville
2008 Triumph rocket 3 touring
Tried to post some pics but they will not let me, That is cool really would have liked to share more. IMG_1193.JPG stand worked out really well. Really happy with it. $299.00 bucks but now i can work from a chair.
I had to stand up, stradle motor to break crank case bolts, took alot of arse
Mike Rocket
Rocket 3
East Anglia, England
2014 Rocket 3 Roadster
I would also highly recommend puting a smear of grease on the bolt when putting it back together. I also do the same with the axles and especially with the bolts that go into the rear fender for the panier mounts etc.
I had trouble with seized bolts in the rear fender and front engine mounting bolts on my R3 roadster. Now they are all put back with grease. I think Triumph put most if not all of the frame and mounting bolts in dry.
In fact i have removed & lubricated all the bolts i think may be going to seize. (due to our wet climate in this country)
Years ago i had to drill out a front engine mounting bolt on a Yamaha XS500, what a job that was, the bolt was corroded all the way through
the aluminium engine case and it was a risky job not to screw it up. Luckily it worked. It took nearly a day to do it.
Kevin frazier
Widowmaker!
Nashville
Have not ordered yet. I have a on going list of parts and when it reaches free shipping then I order. Need to look at it first and then take it from there.
Oh the ole on going parts list. I think im done finally. for a minute
sonny
Thread starter
Henryetta Oklahoma
rocket three x
Calling it a day. Tired and hurt like all get out. IMG_1203.JPGIMG_1205.JPG This is getting powder coated. Completely striped down and have new replacment parts. The hit marks on the cover is from a Raccoon i hit one night. Figure at this stage of the game i am going to do a valve clearance check. This way i can order new shims and have them ready. IMG_1207.JPG No issues here either. Chain and guides plus detent spring getting replaced. I have never replaced the detent spring but figure it is time. Of course this is not going to be replaced right now but final assembly everything will be brand new. Going to replace the kickstand sensor. It is very rough looking. The list of parts never stops.
Kevin frazier
Widowmaker!
Nashville
Before you undo detent spring please post a picture of how it is hanging. Over the top hooks better than up from bottom. I think it puts undo pressure on spring where alot snap. I bet yours is over the top and open faces bottom of engine. Thanks bud
Kevin frazier
Widowmaker!
Nashville
If you forget anything let me know that triumph gasket kit ishrub and i picked up is loaded with odd bits
Tripps
Retired superhero
Florida and NY
R3T,Sprintona,K1200GT, Blackbird,r/65 hack
Curious what you mean by over top or over bottom. Looks like it can only go one way.
Similar threads
