Speedo arrived. Less than 48 hours after I ordered it. Can't do much better than that.
I've also ordered an Oscilloscope so I can check out what signals are coming out of the ECU as far as tacho and speedo goes. That should arrive within the week. I've read the other threads on here about it so we'll see how that goes getting it all to work. May need a pull up or pull down resistor on those wires.
Worst case scenario, I just plug the tach wire into the coil and use the included magnetic speedo sensor. But if I can get it to work with the existing loom I'll document how I did it here so everyone else can know how to make Acewell gauges work on the old Rockets.
The tricky bit might actually be mounting it in a tidy and factory (ish) looking manner.
