No tail light or licence light
Lester1234
Standard Bore
2007 rocket 3roadster
I recently purchased a 2007 rocket 3 roadster. The tail light and licence plate are not working. The brake light works, and when I turn the key to park, the tail light comes on.Any help. Thanks
Stillserving
Nitrous
Southern MD
86' Magna, 2017 R3R
The 12V source for the taillight and plate light come from a different place in Park than it does w/ the ignition in run.
Does the license plate light work in Park as well?
That would rule out the 12V feed wire to the tail section for those lights and the bulbs/housing.
Does the backlighting work on your clocks?
Being an '07 have you looked at your ignition switch?
Lester1234
Standard Bore
Thread starter
Lol I just found a bad 5amp fuse. Problem solved. I should learn to try the easy stuff first. Thanks
Similar threads
AdBlock Detected
I've Disabled AdBlock
