In regards to gaskets. Pretty soon I'm going to put the headers back on. On main thing that was told to me, was to have the headers sit on the system loosely, and after you put on the exhausts and everything, that's when you tighten everything together.
With the headers, do I have to left them up a bit, and then crew on the bolts, and when the bolts I screwed on, finish the job with a torque wrench? 19nm is the setting I believe.
Just whenever you tighten bolts up if there's multiple bolts tighten a little at a time, evenly, or it will leak on anything. In your case the 2 bolts on each header, snug them up evenly and torque them evenly, like divide the full torque by 4 or 5 and work your way up evenly. The rest of the exhaust is just clamps and hangers, put together leave it loose till you get it all together, are you getting rid of the cat??? You can get a decat on eBay unless you're exhaust doesn't need one, a complete system shouldn't need it, but you will have to retune the fuel ratios after, you can get tuneecu and get it close, download a premade.hex file and install it, unless you have a Dyno and know how to set it up, I don't that's way beyond my expertise, I didn't even read or research that part, I just had tor's on it when I bought it and the guy had it tuned for that, but I added a k&n box filter and the decat and installed Nell's tune from tuneecu, once I'm happy with the way it's running I'll change the plugs and have it set on a Dyno, enjoying it!!!
You will find a manual, and a lot of good info in idk signature, he knows his stuff, and warp9 is a God on here. Big ty to both of them
