Only have to work if fitted, on the SVA it would have required to test if required and your SVA did not require them so MOT does not require it. However mine went through the SVA with LED brakes lights that flashed a couple of times before full on. but failed MOT as should be a solid brake light when applied. I would suggest going to another MOT tester unless you want to fit them.
