Exhaust arrow of the TFC for the R3 motorcycle
Wiigit
2020 Rocket 3 GT
The only difference between the arrow exhaust and the standard exhaust is the pretty covers that say Arrow. The exhaust "box" is identical. You can see the exhaust box being modified in this video -
Tal
Christchurch, New Zealand
2022 Triumph Rocket 3 Triple Black
Exactly right Tal.
What you see as Carbon Fibre style "Mufflers" are only covers over the welded on exit pipes.
...and... i have been on my knees out there today taking them off and adjusting the bolt holes...bending the plates to try and make them fit neater since i have added the new boom box...they never seem to go back on exactly the same!...grrr...you need girl hands to fit into a couple of those awkward spots they put bolts in!...no wonder theyre assembled in Thailand where their hands are small......no good if your hands are xl like mine!
Dr.D
Octane Boost
Tazewell TN
Indians and the R3 2014 Roadster + TFC
Exactly right Tal.
Well this is not what I was told by the factory rep. Have I been lied to or was he mistaken?
Paul Bryant
Hamilton. New Zealand
2006 Rocket
If you take a close look under/around the "Mufflers" you will see that the outlet pipes are welded to the box.
The Carbon covers are simply attached to the outside.
There is no removing the mufflers as such.
Tal
With due respect Doc, i dont know what the rep told you.....but i have had my system rebuilt on my GT ..im thinking the TFC is the same as the GT and the R. If you look at the bottom photo of Paul's, you will see the wee bridge like bits...these are where the cover panels are attached which when assembled look like mufflers...the panels have small tongues which slide into these bridges...they have rubber grommets over them to stop the rattles...then there are small bolts which hold the panels tight.
I have spent a few hours i must say trying to get everything lined up to my satisfaction so it looks right.
Id'e be interested to learn if your system looks the same on the TFC.
tgessner
.040 Over
Munich, Germany
Rocket 3R
I think you have to take a very critical look at what Triumph wants to make you believe are differences between TFC and stock. Making substantial and physical changes between both models - like a different exhaust/emission system - would have resulted in two separate and expensive homologation processes. Differences between the two models are mostly cosmetic, I am afraid.
